Buying a Genie 2 combi or TMT
Serginious
Re: Buying a Genie 2 combi or TMT
Post by Serginious »
hello, i want to start buying some new equipment. I was looking to buy a heat press , but i want to have more options to do more products. I have went at Themagictouch and seen all their equipment and was looking at the cheapest press but it has no other options:
https://www.themagictouch.co.uk/product ... cm-x-38cm/
i was thinking to buy one i have found on Listawood
https://www.listawoodtradesupplies.com/ ... MBI&pgnum=
The listawood looks a bit like all the chinese 8 in 1 presses. Any suggestions ?
My budget would be around 500
Thank you
GerryG
Post by GerryG »
Personally if it was me, I'd avoid any of the 8 in 1 press types, they are either a hit or miss, whilst the price may seem appealing, at some point or another you may run into problems with the press, inconsistent heat across the platen, un-even pressure, the list goes on. If you want to print items with the intention of running a small business or hobbist it's worth investing in a press that gives you good constant results. The one you have mentioned above by The Magic Touch, seems a better quality, I think these may be made by Galaxy Press/Lopo as they have very similar looking models. If that is the case, being a Galaxy Neptune owner it is a great press, never had any problems with it, so I'm sure they'll use the same quality parts as in The Magic Touch Press. If you can risk stretching your budget, you could always pick up an Adkins or Pressmech press second hand on eBay. I also have a Pressmech, possibly one of the better heat presses around. If anything else go for a bigger platen at least A3 size, this will cover you for doing a vast array of items to print/sublimate.
Mrteajunkie
Has thanked: 5 times
Been thanked: 3 times
Post by Mrteajunkie »
Skimp on a press and you will regret it for ever.
Save a bit more and buy a decent press and expand go with what you can afford but don’t go cheap all in one.
think about what your going to make and what your profits will be and how you want to move forward.
Do you have the equipment to print or cut vinyl for tshirts or are you thinking of creating mugs first?
