RICOH e3300 LEAVING TRACK MARKS ON PAPER
THE METAL MAN
Re: RICOH e3300 LEAVING TRACK MARKS ON PAPER
Post by THE METAL MAN »
Hi
can anyone let me know how to get rid of track left on prints
What paper are you using?
jennywren
Post by jennywren »
I find in the winter it leaves tracks, being colder it takes a little longer to dry, I switch of fast print and that helps
jennywren
Post by jennywren »
Sorry for the double reply the page keeps telling I'm not logged in and I writing my answer again.
THE METAL MAN
Both papers bought from you Martin
jet col and truepix
David
Jetcol papers can cause track marks as the ink takes a while to dry. Rollers might have picked up ink when printing onto Jetcol and this is being transposed to Trupix. Can you print a few sheets of blank papers using normal paper to get rid of any ink on rollers. Try what jennywren says as well.
THE METAL MAN
will try blank later
have run quick and quality
still the same
DAVID
jennywren
Post by jennywren »
I only got the track marks when I had a design which was crest placed in the middle and both sides, never a full picture covering the whole of the mug when it was damp and I could print with fast print, really weird, If I have a order where it more white than picture, I place a lamp by the printer half a hour before I print, sometimes till I printed the mug you couldn't see the track marks, but now taken these silly precautions it is only once in blue moon it happens. I feel your frustrations.
THE METAL MAN
All was going well then bang track marks
just when i have large order for Monday thank's for you help
DAVID
