Sublimation Oven and 42 Mug Wraps
Re: Sublimation Oven and 42 Mug Wraps
SOLD
For more info please see:
https://www.ebay.co.uk/itm/264773401723
It comes with over 42 mug wraps which alone are worth over £300. Not sure what I am thinking here :-)
If you offer over £165 then it will automatically accept.
Note that we only ever used this for the oven, which works perfectly, but unsure if the vacuum side works correctly so please buy if you only want this for the oven side of things and the vacuum would be a bonus if works!
[ATTACH=CONFIG]6250[/ATTACH]
vB_ID:6250
vB_ID:6250
Hi Olly
Not particularly interested as I already have one, however its really easy to test if the vacuum works. Just turn the machine on and press vacuum. If you hear the pump then put your finger over the small threaded hole in the bottom corner of the machine, if you can feel the tip of your finger being sucked in and the vacuum pump changes to a different noise then its probably working.
Imagine a vacuum cleaner that all of a sudden becomes blocked and how it changes
