Epson Eco Tank Pigment ink
Mark23771
Re: Epson Eco Tank Pigment ink
Post by Mark23771 »
Hi all only joined today And a total Newby I’m looking at purchasing a mug heat press
and also an Epson eco tank printer ET-2720 this comes original Epsom Inc which I think is pigment ink as far as I’m aware
do I need to change the ink to be able to print on mugs and T-shirts.
this may be a really silly question but I have no idea.
pw66
Post by pw66 »
To print mugs and polyester t-shirts you will need to change to sublimation ink. To print onto cotton t-shirts you will need to stick with pigment ink and use transfer paper.
Mark23771
Post by Mark23771 »
pw66;143637 wrote:To print mugs and polyester t-shirts you will need to change to sublimation ink. To print onto cotton t-shirts you will need to stick with pigment ink and use transfer paper.
One more question to add to this if I wish to print onto vinyl stickers do I need pigment ink or sublimation ink. Thanks
pw66
Post by pw66 »
To do it succesfully you need solvent ink - printers start from £4.5k upwards. There are sublimation and pigment ink vinyls that can be printed but the results are not good.
