colour difference between mug and water bottle
smiley_mug
Re: colour difference between mug and water bottle
Post by smiley_mug »
I've used the same colour red on a water bottle as I usually use on my mugs but it has come out different (slightly pinker). Is this difference normal between different sublimation products or could it be time/pressure?
Mrteajunkie
Has thanked: 5 times
Been thanked: 3 times
Post by Mrteajunkie »
It’s all down to time and material.
mugs are ceramic whereas your water bottles are probably aluminium?
Each need certain time and heat settings to get the right press result.
Of course if it’s cheap products your using that could also affect the outcome slightly.
