I have wanted to have a try of t-shirt printing and wall stickers etc for quite a while now and I finally have some spare money to have a try so I am wondering if people think that this set up would be ok
swinging heat press from signzworld
https://signzworld.co.uk/shop/bluewave- ... -transfer/
printer from ink experts
https://www.inkexperts.co.uk/product/su ... -a4-paper/
cameo 4 cutter from MDP supplies
https://www.mdpsupplies.co.uk/silhouett ... packs.aspx
i would just like some advice as to if I am making a mistake on what I have chosen please any advice would be great fully received
thank you
Neil
Help with buying equipment
Re: Help with buying equipment
Hi Neil,
A good starter press is the stahls clam basic from target transfers, I've had one for years, never let me down, a good back up press really good temperature spread and accuracy, comes in a range of sizes.
Cameo 4 is good
I prefer Sawgrass SG400 and SG800 as opposed to an epsom ( I can see why epson appeals but, I like the sawgrass package personally with hd inks)
Just my preference, sure others will have good input .
Cameo 4 is good
You obviously had a lucky one - mine fell apart and doesn't keep good temperature. Too expensive for mid-grade Chinese import.billy8581;143178 wrote:Hi Neil,
Cameo 4 is good, and Ink Experts will sort you out with a good printer.
pw66;143182 wrote:You obviously had a lucky one - mine fell apart and doesn't keep good temperature. Too expensive for mid-grade Chinese import.
hi what press did you settle with then please
I upgraded to a Pressmech, but at over £1k is a different kettle of fish to a £600 Stahls basic.Whambam;143183 wrote:hi what press did you settle with then please
The problem with buying a cheap press is that it is pot luck as to whether you get a good one or not, and there is no way of knowing what you get until you have been using it for a while.. Some will last well and others will be a pain from the get go - as was proven by my Stahls basic.
All I can recommend is that if you buy a budget press get it from a reputable supplier with a good returns policy.
Never dealt with Signzworld, but they have some very dubious sounding terms in their returns policy.
Also Signzworld make you checkout through Paypal ( even when using a card) so you are not covered by the Consumer Credit Act if anything goes wrong.
Great I will look into that I know ink experts have one for £200 so I might try them as they are members on the forum so should get good support as they where great over recommending the printer
thank you
thank you
