Et-2720 first steps after unboxing
Daninho
Re: Et-2720 first steps after unboxing
Post by Daninho »
Hi,
i will receive the ET-2720 tomorrow as the ET-2710 was sold out. The Sublinova ink and the paper from inkexperts.uk will also arrive tomorrow. Now the problem is that the sublinova ink comes in bottles not suited for the ET-2720 models because as many know the newer Ecotank models using special nozzles on the ink bottles. I found a shop which sells empty Ecotank bottles for refilling but now i am not sure anymore if they will fit because in a youtube video i saw an ecotank with "color coded" nozzles, like you can not put the black bottle on the blue ecotank nozzle but my empty bottles look all the same to me, so that could be a problem. Is there another way to refill the new ecotank printers with normal bottles? I am concerned that i might put air into the system because of all the refilling. Are the first steps with the printer identical to normal ink? Like i saw in a video that you have to push a key for starting the pump inside the printer, for sucking in all the ink to the printheads when you first start it.
InkExperts
Post by InkExperts »
Ahhh, yes with the newer Ecotank bottles we fill them using a syringe and needle. No need to worry about air in the ink tank the air rises to the top and vents out. Had we known I would of happily put some in with your order :( if you can get hold of some 10ml syringes and metal needles they work a treat for filling the ink tanks.
Alex
Daninho
Post by Daninho »
Yes i already orderer syrings yesterday but they are 60ml with a dull metal cannula as a tip. I hope they will fit trough but they are only if my emtpy ecotank bottles wont work and i think they will work because they have a universal nozzle, that fits on all colors.
InkExperts
If the needle is less than 2mm diameter it will fit in the gap on the ecotank top and all should be good.
Alex
Daninho
Post by Daninho »
yes its 1.2mm according to amazon but its on the shorter side with 3.8cm. This could be also a good way to suck ink from the tanks if something is wrong with the printer and it need to be cleaned and flushed but in that case with a much longer cannula. I will write you a mail as you suggested regarding the ICC profile
Daninho
Post by Daninho »
InkExperts;141793 wrote:If the needle is less than 2mm diameter it will fit in the gap on the ecotank top and all should be good.
Alex
Thanks you, everything worked well. Since i dont have any Polyester fabric i wasnt able to test sublimation for the first time but the printer works well so far on normal paper. I even checked your ICC Profil just because i was curious and the ICC from sublisplash and some others for Epson printers but different inks. What i can say is with the original Epson color management it looked similar to the screen but i guess thats normal since the color change during sublimation? All profiles and even the Epson have problems with blue, its kind of purple most of the time on paper.
