Softest Print and Cut Transfer, same feel as plastisol screen print, for Darks
Boyan
Re: Softest Print and Cut Transfer, same feel as plastisol screen print, for Darks
Post by Boyan »
Hi,
If someone needs i provide quality HTV Print and Cut transfers, any quantity, big or small. One Offs no problem.
The vinyl is 45 microns, Soft Print 3.0 . This is the softest HTV available at the market and the result is same feel / not similar/ as plastisol transfer. I know, as i have a retail shop and sell T shirts and clothing using top quality plastisol transfers and print and cut transfers.
To compare the normal Poliflex Premium vinyl / POLI-TAPE Germany/ is 100microns
It's printed on a 6 color pro Roland printer 1440x1440 resolution, using Eco Sol Max 1 inks, not 2 or 3 , so this is the strongest ink possible for the best result. Color calibrated prints.
This is the most difficult vinyl to produce transfer, as most people even can not do it at all. It's very difficult to take it off from the carrier sheet without damaging it, next to impossible would say. It is extremely flexible PU material. Cost me a lot of time and trials but have mastered it.
So probably not many place to obtain what i am offering here. I have tried all on market and this vinyl is way ahead of all competition.
For white, sublimated sportswear, leather, detailed cuts with some weeding i have other separate solutions for each scenario, same thickness 45-50 micron each from different brand.
This one's for T shirts, jackets, sweatshirts etc. where soft is a must. Or a big piece is needed.
I am in Spain , but as sheet is not heavy and my price is good , it can be shipped fast anywhere in EU or worldwide. Best of all you can use even an iron for this vinyl, or a cheap heat press. Following my instructions.
Combining different transfers on one sheet is accepted, though for this vinyl there are some minor requirements.
Here are the prices:
10x10cm = 1
15x15cm = 2
20x20cm = 3
A4 = 3.5
30x30cm = 4
A3 = 5
50x50cm = 8
100x50cm or 1/2 sq metre = 13
200x50cm or 1 sq metre = 20
You receive READY TO PRESS TRANSFERS> PEEL BACKING AND PRESS
Invoice could be issued /+21%/ or if VAT registered in EU / oh yeah Brexit/ invoice without a VAT.
Obviously the more you buy the cheaper it gets. These are already wholesale prices meant for business to business. No further discounts are offered. Clever guys like you could easily see that a T shirt with a 30x30 image on front could cost you 1.30-1.5€ per piece. How's that price for a custom transfer /one off / when order 1sq m...
Contact me if interested. Some samples:
[ATTACH=CONFIG]6013[/ATTACH][ATTACH=CONFIG]6014[/ATTACH]
vB_ID:6014
vB_ID:6014
vB_ID:6013
vB_ID:6013
20191223_141504 (1).jpg (96.5 KiB) Viewed 253 times
