Can you sublimate on spunbond polypropylene?
RS1
Re: Can you sublimate on spunbond polypropylene?
Post by RS1 »
Hello,
I've heard a lot about sublimation on polyester and was just wondering if you could also sublimate on 50-70gsm spunbond polypropylene (a non woven material)?
Thanks!
Andrew
Post by Andrew »
I would think you could. Might have to fiddle with the heat level and time as I believe it is quite a thin material but should take a print. How well though is a different question.
logobear
Post by logobear »
try ironing a sample with domestic iron on hottest setting ... what happens to it?
RS1
Post by RS1 »
Thank you Andrew and logobear for your responses, much appreciated! I will pass the advice along to the company that I was working for during the holidays.
Fabric wholesalers send out samples (usually free) - so get a sample and test it.
RS1
Post by RS1 »
Thanks pisquee!
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
