Green Heat Conductive Rubber Pad
GermanDyeSub
Re: Green Heat Conductive Rubber Pad
Post by GermanDyeSub »
Hello,
I am trying to source a Green Heat Conductive Rubber Pad as I will press on ceramic tiles 5x5 cm which are not fully flat.
I don't find a supplier in UK or Europe. All I find is from US sites, so want to avoid expensive customs :)
Perhaps someone here could point me in the right direction. Would be truly grateful for that? As long as it's in UK or other Europe, it's fine.
Perhaps [MENTION=1332]Earl Smith[/MENTION] knows a German supplier that supplies it. I have looked at Printequipment's site, but not found anything of use so far.
Thanks.
Post by GoonerGary »
For flat ceramics I've used thick ironing board felt covered with teflon sheet...to make a pillow. Or blue silicone sheets as seen here:
https://www.ebay.co.uk/itm/Silicone-Ext ... SwZola8Vzs
https://www.ebay.co.uk/itm/330741950015 ... 0065746379
Earl Smith
Post by Earl Smith »
https://www.y-o-w.com/en/silicon-mat-40 ... 09-401-12/
Article number: 100-109-401-12
I bought this a while ago but never used it for tiles as I dont do them. I have an Oki white A3 printer and it important that the pad on the press remains totally flat. A slight dent and the A and B papers for the forever system will not bond together.
I use my silicon pad for the Forever Multi Trans papers.
Hope this helps.
Earl Smith
Just remembered another place you could try. TMT or The Magic Touch. When I originally bought my white toner system , I bought their system. ( Since bought an A3 printer and the Forever system ). TMT supplied a silicon pad with the setup. That might work for you too. TMT is in germany, not as helpful as the english TMT supplier but at least you could order it from here.
GermanDyeSub
First of all, thank you [MENTION=239]GoonerGary[/MENTION] and [MENTION=1332]Earl Smith[/MENTION] for the helpful advice and links.
I will have a look at the links and will buy something suitable for pressing my tiles. Thanks once again :)
GermanDyeSub
An update.
Was told that it would also work with a teflon pillow as the tile will sink into it so also the unflat part will be sublimated. So, a solution building on what [MENTION=239]GoonerGary[/MENTION] has mentioned here earlier.
