[ATTACH=CONFIG]5949[/ATTACH]
In an attempt to free up some space, I'm selling my A4 Photopolymer Platemaker.
Recommended for hot foil , letterpress and pad printing platemaking . Also for making moulding masters, film negatives, shallow plate china glazing and rubber stamps using an optional attachment
Originally purchased for producing foil stamping dies in-house, it only got used a handful of times as the majority of the time we use thicker acid-etched/machined metal dies.
Full specs can be viewed on the Polydiam website (although please note that the 'External Digital timer' in the features list is either an error, or has been added since ours was purchased. - it's just the mechanical timer)
RRP £490+vat (£588)
£250 inc mainland delivery via DPD
I've also found the manual, approx 10 200x300mm negative film sheets, and 2 part bottles of developer fluid / fixer (1 of each with approx 700ml remaining)...which I'll include.
Polydiam PSE-A4 Platemaker - Table-top Photopolymer Platemaker
Re: Polydiam PSE-A4 Platemaker - Table-top Photopolymer Platemaker
- vB_ID:5949
- PSE-A4-Platemaker-e1471429182186.jpg (23.26 KiB) Viewed 2 times
