I have search the internet and can't seem to find a correct answer. I am using a Ricoh 7100 printer if this is any help
Thanks for any help
I agree to a certain extent, when printing large images as you are. However it is still of limited relevance - the cost of the paper far outweighs cost of ink. As there is a close correlation between paper size and ink use as long as you are costing your paper correctly then you will always be on the correct side of the ink cost.pisquee;140376 wrote:Well, yes and no
We use a large format Epson with InkTec inks and their transfer paper, and when you're printing metres of fabric then the cost of the ink and sublimation paper does matter, even though it's way cheaper than Sawgrass, - hence I came up with the weighing the carts thing to have an estimate of ink costs per square metre.
We have the costs per linear metre for the paper, along with the costs for filling that area, as most of our work is printed textiles which do fill the page with lots of ink - they are separate lines on the costings spreadsheet, along with everything else. You could extrapolate your argument to say no of the material costs need factoring, as it's the labour which is the main cost, and then all of it is irrelevant as they bare no relation to the RRP on some of the products, but knowing your costings is important when you have to buy some more rolls of paper, or more sets of litres - the cash flow side of things is important too for restocking, aside from knowing how much the paper and ink cost is for a cocktail chair.pw66;140377 wrote:I agree to a certain extent, when printing large images as you are. However it is still of limited relevance - the cost of the paper far outweighs cost of ink. As there is a close correlation between paper size and ink use as long as you are costing your paper correctly then you will always be on the correct side of the ink cost.
We will have to agree to differ on that.pisquee;140384 wrote:We have the costs per linear metre for the paper, along with the costs for filling that area, as most of our work is printed textiles which do fill the page with lots of ink - they are separate lines on the costings spreadsheet, along with everything else. You could extrapolate your argument to say no of the material costs need factoring, as it's the labour which is the main cost, and then all of it is irrelevant as they bare no relation to the RRP on some of the products, but knowing your costings is important when you have to buy some more rolls of paper, or more sets of litres - the cash flow side of things is important too for restocking, aside from knowing how much the paper and ink cost is for a cocktail chair.
