Looking for:
Help in finding new products.
Dan-yorks
Re: Looking for:
Post by Dan-yorks »
Evening guys,
I'm looking for the following:
  • Double sided sublimation "business card size". either a plastic of aluminium, preferably .4mm+ thick.
  • Same again for A4 sized sheets, probably aluminium for a more rigid board.
Best places to go to and try some samples?
Previously used a DYE sub supplier for the cards, but they changed material supplier and now, they are quite frankly crap. Thin paper like things..
Side note.... I tested some from amazon, silver in colour. They worked perfect if not for the thickness. I see a lot of silver ones but they are advertised as "single sided only"... did I get lucky? Or what other sorcery was at work here for them to work?
Re: Looking for:
Moved into sourcing new items forum.
