Printing brownish on everything...
yaseenin
Re: Printing brownish on everything...
Post by yaseenin »
can anyone help me pls, i have an epson L130 filled with sublimation ink, it was printing good and the colors were good at the beginning, but now they seem brownish , the color on paper seems fine but after heat pressing it changes that way, mug, key chains , shirts, it all comes Like a Sepia filter on top of it... Thanks in advance,
Hi. What brand of inks are you using and do they have expiry dates?
Since you are having problems with mugs and also flat-pressed items it doesn't seem to be a press temperature problem, however, if you have a combo press where all units use the same controller, it may be a controller fault.
Users browsing this forum: No registered users and 11 guests
