Heating press for a 38x38 size
Re: Heating press for a 38x38 size
Hi I was looking to start up a hobby/ small business for local work looking to print slate chopping boards and the Odd t-shirts could anybody recommend a swing heat press for the size 38 by 38 as I'm getting confused with different ones please was thinking of going for the sawgrass 800 but then again with the Epson printer be just as good????please someone help me....... decisions decisions
Are you asking for recommendations for both press and printer?
Do you have a budget in mind?
Yes I would be interested in your thoughts I was thinking of buying sawgrass 800 the only reason is that you get the software with the sawgrass but for heat presses I'm getting confused as there so many
To a certain extent when starting up (unless you are printing hundreds of items a day) the heat press is more important for sublimation than the printer. Temperature needs to be accurate and consistent accross the entire platen, and you don't always get that with cheaper presses.
Epsons will work out cheaper to buy and run. The Eco tank ET14000 is about half the price of the SG800 and will arguably give a better print. The guys at Ink Experts will be able to advise you further.
Put the money you save towards a Pressmech A3 heatrpress from Nova Chrome, at just over £1000. Slightly larger than you want at 38 x 50 but the quality is second to none and the size will be good for t-shirts.
Just realised this post was made in the 'Forum info' section, I'll move it into a different category for better exposure.
thank you for your help but could you tell me what software would be good to use and best paper ,I'm mostly looking to do slate prints and chopping boards ,
thanks again
thanks again
hi what do you think on the HP5-1 swing press 38x38 ? and can you add different sizes of mugs to it.....
also what the best chopping board as in glossy /chinchilla ....
