Use soldering mats for Umbrellas
Dan-yorks
Re: Use soldering mats for Umbrellas
Post by Dan-yorks »
Whilst I'm totally new at dye-sub'ing. I thought I'd share our solution if you're using a full size platen.
Totally neglecting the fact that plastic melts on umbrellas. It never crossed my mind the first time I did it. We needed a way to raise the fabric up above the plastics.
We bought a couple of these soldering mats from Amazon for £8.79 each, cut one in half and stacked all 3 left over pieces. Making it much easier to tape the paper, pull the handle and hold the plastics away - all solo! A little dye to transfer through, so lay some paper on top of the mat.
A cheap solution / handy tip! (don't expect many more.. there'll be a ton of questions from me soon).
mrs maggot
Post by mrs maggot »
60cm x 40cm silicone baking mats are also easy to use, and normally about a fiver when Aldi have them on offer, I have several whole ones left and a few cut up into shapes for certain items I press. A couple have actually stayed in the kitchen for pastry.
Dan-yorks
Post by Dan-yorks »
Handy to know Mrs Maggot. I considered these - but wasn't sure about the heat resistance of them. So went a little overkill with 500 degrees !
