looking for swingaway heat press recommendations, pixmax for instance anyone?
gavtheoldskater
Re: looking for swingaway heat press recommendations, pixmax for instance anyone?
Post by gavtheoldskater »
i need to buy a new larger swingaway heat press but can't stretch to an adkins or similar quality one, can anyone recommend anything 38cm x 38cm or larger?
the pixmax one for around 200 looks like it may be ok, anyone own one?
Try and look for used quality presses - you can sometimes pick up adkins and pressmechs on Ebay pretty cheap, better buying something high quality but used, than something that's just cheap.
Frostee
Post by Frostee »
my now secondary press is a pixmax (clam though) but works well, even heat etc and was running as my primary press for around 3 years before i bought a bigger swingaway press
Graphtec CE6000-60, Sefa Rotex Pro Auto Open Swing, Galaxy Mug Press Pro, Epson P800 with sublimation inks, Ryonet Screen print setup
