Problem Heat Pressing Bone China Mugs
Gracie_liz
Re: Problem Heat Pressing Bone China Mugs
Post by Gracie_liz »
Hi,
I am new to this forum but could really do with some advise please. I am having trouble dye subbing Bone China mugs. The print seems to come out quite blurry like the dye is bleeding out. It doesn’t look like shadowing from movement as the bleeding is around all edges and not just in one direction.
Also the colour doesn’t seem to pop as much as my other dye sub products is that because it is bone China?
These are the settings etc
Printer is SG400
paper truepix
press Genie III
temp 180’c
time 180 seconds
listawood balmoral mugs
Please help!
Has thanked: 13 times
Been thanked: 12 times
I avoid these mugs wherever possible, the print is never as good as a normal ceramic mug. Suppliers tell me its because of the material thickness. Colour and clarity are never as good.
Sorry that's not much help to you.
Gracie_liz
Thank you for your reply, it does help thank you, at least I know I’m not going mad
Ricky@Xpres
Post by Ricky@Xpres »
Hello Gracie_liz
Try dipping the mugs in water after you have pressed them, this will stop the sublimation process and the image should stay sharper.
Ricky
Xpres
https://www.xpres.co.uk/
pw66
Post by pw66 »
Is your paper slightly damp? Try puting a blank piece into the press if there is steam for a few seconds then it is damp.
Can we have a photo perhaps? We print more bone China than ceramic with sg400 and genie 3 do should be able to shed some light.
Gracie_liz
Thanks I will give this a try.
Gracie_liz
vB_ID:5748
vB_ID:5748
Here is a photo of the quality of the image. It just looks quite blurry?
That actually looks pretty good for bone China. I wouldn't water dip after due to cracking but do make sure you are placing above a cool fan within seconds and perhaps drop temp to 170c if you're using sawgrass inks. Bone china for us sells really well but indeed very different beast to standard ceramic coated mug.
Gracie_liz
Thank you!! I will give it a try lowering the temperature slightly and see what happens, but good to know that this is the sort of quality print to expect on bone China. :smile:
