Stickers/Decals best rioute to go down.
Re: Stickers/Decals best rioute to go down.
Hey guys, I am looking for some advice.
I am looking to get into making stickers/decals mainly for bands, so these would be [LEFT]indoor/outdoor/windows stickers etc.[/LEFT] and for other doing other projects as well.
I have a colour laser printer 'Brother HL-L3210CW', so not sure if there's anything I can get for that to just start off, as it seems if there is, that it could be very costly doing it that way.
I've seen the Roland BN-20 which seems to be perfect for what I want to do and has versatility to do other things, but has a hefty price tag for a newbie.
So i am wondering what advice/route you could give for me to go down, what i could look up and research with machines/vinyl/paper,
and even if the Roland Bn-20 would be a good goal to try achieve for what I want to do.
I'm also wanting to do sublimation, which is the main reason why I joined the forum, would the Roland BN-20 be suitable for sublimation printing etc?
Thanks in advance!
Thanks in advance!
Xpres_Adam
Hi Cook_58,
It might be a good idea to take a look at the Roland BN-20 in person, this way you can see the process and results, you can then see if it's for you or not.
We have a showroom in Castle Donington just next to East Midlands airport and have lots of Print&cut machines, sublimation printers, laser printers, UV printing and more in our showroom.
You are welcome to come and see the kit with us if you think it will assist in your decision of which technology would be best for your business.
If you would like to; feel free to get in touch and we can arrange something (my details are below).
Thanks,
Adam
Thanks,
Adam
Adam Roberts | System Specialist
Tel: 01332 85 50 85 | DDI: 01332 85 53 29
Fax: 01332 85 50 80
Web: www.xpres.co.uk
Email: Adam.Roberts@xpres.co.uk
Fax: 01332 85 50 80
For outdoor and window stickers you'd need an eco-solvent printer due to the effects of UV light from the sun. So yes, a BN-20 would be ideal for these. However, a BN-20 is of no use to you for sublimation printing, so you would need a different setup for that.
Any recommendations for machines I should look at for sticker printing, that's not as pricey as the BN-20
Sent from my SM-N960F using Tapatalk
What size stickers are you intending to print? You mentioned window stickers in your first post so you may need a large format printer with eco-solvent inks and, if not a BN-20, then you'd need a separate countour cutter wide enough to handle the media and capable of doing print & cut from printed registration marks.cook_58;138167 wrote:Any recommendations for machines I should look at for sticker printing, that's not as pricey as the BN-20
Stickers, in themselves, are cheap items, but you require some serious gear to do them properly.
the BN-20 is really slow and media limited due to narrow width.
Mimaki worth a look, when you compare specs to the bn20.
We use a latex printer but I would recommend.
If it something you're doing regularly then you can justify the outlay of an exo solvent, bear in mind cutting them out as well.
If you're not doing enough to justify or do occasional large runs just contract out.
Sizes would be a anything from about 30/40cmm up to 10cm+ for bands etc, window stickers would probably be a bit bigger. Not 100% sure as I'm just looking into it.webtrekker;138168 wrote:What size stickers are you intending to print? You mentioned window stickers in your first post so you may need a large format printer with eco-solvent inks and, if not a BN-20, then you'd need a separate countour cutter wide enough to handle the media and capable of doing print & cut from printed registration marks.
