Sawgrass test what file type ?
Leadbelly
Re: Sawgrass test what file type ?
Post by Leadbelly »
If you wanted to send a file directly to your sawgrass printer from your own software by-passing the creative suit as a test comparison which file type would you send hoping to see the best results?. It would be a graphic image with text on truepix paper to be applied to a mug from Coral draw.
LB
I would just print directly from Coreldraw using the correct ICC profile. No need to 'send' any files.
