Mug sublimation intermediate level, noticing some inconsistencies on the prints. Press is a freest double press.
Print size isn't too big, well away from handles and a good 0.5cm from base, mugs preheated on radiator for natural warming up pre pressing.
Should I be looking at pressures next?
Inconsistencies are exactly that, sometimes the print is that good I consider quitting my day job, other times I notice the fade and it breaks my heart, to add, many of times when the print is blue.
Faded corners
Re: Faded corners
Pressure shouldn't be causing an issue, as long as everything's making contact it doesn't need to be too firm.
What mugs, paper and inks are you using?
Re: Faded corners
Using 11oz mugs from longforteJustin;136811 wrote:Pressure shouldn't be causing an issue, as long as everything's making contact it doesn't need to be too firm.
Epson L382 printer
Freesub double mug press
and inks paper supplied for Citi ink express.
The faded corner and edge seems more persistent, despite prewiring mugs slowly on radiator for natural base warmth and print being easily 2cm from handle too. Little lost at what the issue is on the slight fades on handle edges.
Re: Faded corners
Inconsistent is the best description. I can notice slight gaps at the bottom now and then depending which mugs I put together.Justin;136840 wrote:Are the mugs straight when you put two together? Check the long edge.
