Morning all
i am looking to print onto a BROWN MOTTLED STONEWARE MUG, I hold th licence for a range of metal kitchen ware, but have been blocked from stocking its matching range of Mugs and ceramics.
I have sourced similar non copyright images , but need a stoneware type mug, looking for suggestions from you guys for solutions
Stoneware type mug
Re: Stoneware type mug
I pondered this and hunted around some time ago but drew a blank. I shall pay attention to see if things have changed.
Janners
Janners
Hi this is photo of the mug, I am looking for the light mottled effect the mug shape is not as important
If the texture wasn't so much an issue you could print the mottled effect, as for getting an actual rough mottled surface effect, it's not something I've seen, so you would be looking at getting batches sublimation coated, so depends if you have a big enough market to work to the MOQs
