Printing white on a blue mug.
Tops
Re: Printing white on a blue mug.
Post by Tops »
Hi Guys.....back again 😔
I have a customer who wants blue mugs with white writing, is this possible as I realise when you print on a white mug any white is not printed, but just mug!!, I would appreciate any help asusual👍
Also I would like to print on Longforte 12oz latte mugs and I realise that the printing area is angled and very different to flat sided mugs, my question is how do I replicate the angled side on a template in PS. TIA guys.
I’m running a Ricoh 3110 with sublisplash inks, Galaxay mug pro 4 in 1 GS203, using paper from Xpres 240mm x100mm
You can't print on blue mugs using sublimation. Screen printing might work but I can't comment on the durability or the cost as I've never screen printed.
As for latte mug templates, these are basically an unrolled truncated cone and you need to warp your image in PS to fit the image area. It's possible to download latte templates that use PS Smart Objects so that you can simply place a rectangular image into the Smart Object and the warping is done automatically.
Tops
Post by Tops »
Thanks for the reply, I will pass that on to my blue mug customer. I will research more on the latte side of things. ��
Blue background is your best bet but depending on how close to handle etc. you can get if this would be acceptable
Other ideas, blue inside and handle?
https://shop.bestsublimation24.eu/produ ... nsfer.html
Or......
but maybe not the right style.
I will chip in with....
Blue mug with white print can be done using my OKI white ;-)
Dishwasher safe and very durable as well - obviously not to the durability of sublimation (nothing is), but not had any complaints yet...!
Tops
Post by Tops »
Thanks for this, but I still can’t print on the blue mug in white.��
Tops
Post by Tops »
Justin;135592 wrote:Blue background is your best bet but depending on how close to handle etc. you can get if this would be acceptable
Or......
Tops
Post by Tops »
socialgiraffe;135599 wrote:I will chip in with....
Please enlighten me to what OKI is?
Tops;135719 wrote:Please enlighten me to what OKI is?
An OKI is a laser printer that, in this instance, prints CMY and WHITE.
This means I have the ability to print white on to blue (of any other colour) mug.
cook_58
Post by cook_58 »
I found this while browsing… https://www.ghost-white-toner.com/
