Sawgrass Sg800 Nightmare !!!
Mitch
Re: Sawgrass Sg800 Nightmare !!!
Post by Mitch »
Hey Folks I hope you are all well and living in a Sublimation Fairly Tale :)
I am hoping someone may have had some similar issue that you were able to resolve or give me some suggestions.
I have an SG800 that had a noisy paper jam i have been told - i wasn't there at the time. After they called technical support ( ME ;)
1. I removed the offending paper jam
2. at the back door the grey plastic bar with fins that sits just under the paper rollers had popped out of its place - unscrewed the back door, put that back in place.
3. restarted the printer - sent a job to print .... it gets 3/4 off the way through - then stops and says paper miss feed ????? I have looked for every little bit of paper and every angle possible, cleaned belt etc ... Paper is set correctly on the printer and in the files sent ...
4. open the back door, close it again, cancel the job on the LDC screen - error message goes away.
5. Try print again ... same thing ... everytime
6.I have been on the phone to Sawgrass for 2 days - and they don't know :confused::confused:?.....
If any one as any suggestions I would be very grateful :)
And it seems there is no one that i can find that repair these machines either
at this stage it look like I will splashing out on a new one :mad:!
Thanks for taking the time to read my post
cheers
Mitch
viccar1
Post by viccar1 »
following because im have the same problem with a 3110
Mitch
Post by Mitch »
viccar1;135434 wrote:following because im have the same problem with a 3110
So annoying isn't it -
it printed a couple sheets on Saturday without a problem - but then went right back to doing what its doing ...
I haven't got time to try work out whats going on - I have another on the way now!
Earl Smith
Post by Earl Smith »
I rent space from a Ricoh dealer and he will fix any problem I have. A decent Ricoh dealer near you should be able to help you.
rabb
Post by rabb »
Mitch;135370 wrote:Hey Folks I hope you are all well and living in a Sublimation Fairly Tale :)
cheers
Mitch
Have you changed paper or changed to a new batch?
Measure the length of the paper and check it against your printer settings. This smacks of a path sensor issue.
viccar1
Post by viccar1 »
Well ive taken mine to bits used a air blower on it and then a hoover on it, and it seems to be working properly now, (must admit it was very dusty)
Mitch
Post by Mitch »
rabb;135456 wrote:Have you changed paper or changed to a new batch?
Hi there Rabb
Not changed paper size or type it runs the same stock all the time - yeah I had double check the paper size from the file being sent and what was set on the printer - it was even doing it with A4 sheets when i was testing, some sort of sensor issue is what i think it is too ....
Mitch
Post by Mitch »
viccar1;135459 wrote:Well ive taken mine to bits used a air blower on it and then a hoover on it, and it seems to be working properly now, (must admit it was very dusty)
Happy days :) - glad you are up and running again ....
rabb
Post by rabb »
Mitch;135461 wrote:Hi there Rabb
You may have a slippy roller. If it slips then the paper will not clear the exit sensor on time which triggers a paper jam.
Just needs a good clean out with air duster and platen clean.
Sent from my SM-G965F using Tapatalk
Users browsing this forum: Google [Bot] and 7 guests
