I am having trouble with the 12oz mug slipping out of my double press from Dyesublimation supplies. Anyone know how to solve this problem?
Ron
12oz Latte Mug Problem
RON.ABBOTT
Re: 12oz Latte Mug Problem
Hi Ron
I do not have this press, but I assume it came with instructions. You need to look at them to work out how you tighten the clamp so it holds the mug securely in the blanket.
Hope that helps
Hope that helps
RON.ABBOTT
The instructions are no good I have tried all diferent clamp presures but the mug still slides out.
thanks for the reply
Are you able to post a picture?
Is it the correct heat press blanket for the style of mug you are trying to print?
Only a guess. but the 12oz mugs I have seen are latte types and therefore slightly conical. Are you using shaped mugs and, if so, are you also using a conical wrap in the press?RON.ABBOTT;135157 wrote:I am having trouble with the 12oz mug slipping out of my double press from Dyesublimation supplies. Anyone know how to solve this problem?
Ron
RON.ABBOTT
Yes I am using conical heat press and mugs, I have just used a bent coat hanger to hold the mug. It works ok but is a bit of a bodge up, but it works.
Many thanks for replying Ron
