Hi guys
If I manual pull down needle bar 12 on our Tajima Neo TEJT C1501 machine, the needle tip is out of alignment with the hole in the bobbin plate!
How can this be remedied?
Cheers
John
Needle Bar Misaligned? Tajima Neo TEJT C1501
Re: Needle Bar Misaligned? Tajima Neo TEJT C1501
just bend the metal back .... you probably hit a hoop at some stage ?
Thanks for the reply - I always shy away from bending things
I'll give it a try later.
if it goes wrong, just swap it for one at the far end that you rarely use !
Done that
