What do you guys think about that?
Re: What do you guys think about that?
Well guys, this loom berry interesting.
My gut reaction is the same as The Ghost White toner... it doesn't work...
If this was a genuine set up that had no issues then why did he not print a laser transfer using white, heat press that and then swap the carts out and print the dye sub. In a real world environment cross contamination will be a major issue.
Also, I haven't delved any deeper than watching the video, but unless he is using genuine OKI white toner then you may as well throw the transfers away. Third party toner simply isn't as good for these machines.
I will keep my eye on it, but I think it is a non starter a bit like many other systems that are out there... anyone remember TransSlam?
The only new thing I am looking forward to seeing is the set up from Dye Sub Supplies for sublimation on to dark cotton...
