Hi all
i am trying to print a solid colour but often get a cloudy bit - where the print/ink hasn't been able to produce solid colour - it seems pressure didn’t get to the whole area?
Any ideas for quick solution?
I use a teflon pillow cushion on my A3 press bed.
Patch cloud on solid colour
Re: Patch cloud on solid colour
just sublimation t-shirts, this is a white T with black print... Is the press not hot enough in one area of the plate? Maybe the bed has a crease? I'm not sure.webtrekker;132256 wrote:What are you trying to press?
(I've pressed 100s of T-shirts since last july, but this problem crops up every now and again and ruins quite a lot of T-shirts).
- vB_ID:5203
- 51A144EA-00AB-4D4D-89DD-91067BB8D8AE.jpg (76.09 KiB) Viewed 11 times
- Has thanked: 11 times
- Been thanked: 9 times
Looks like its happening in the exact same spot? What make of press is it? Could be a cool spot on the platen.
Try upping your temperature a bit and test on scraps from your previous misprints. Maybe experiment a bit with the pressure too.
