Chromaluxe chipping
Re: Chromaluxe chipping
I'm working with some large Chromaluxe panels but having some issues. I can't peel off the protective layer without it taking away some of the coating on the corners.
Luckily, I can use a paint marker to spot the print, but is anyone else having these issues?
Chromalue quality has gone down over the years- we can't use it anymore due to this - having the pring peeling off is not pleasing to customers, who then think we've just printed a sticker and stuck it on.
I was talking to a production consultant and he thought it was due to banning of Chromate which is a chemical used in the bonding process, or something like that - or a chromate type was banned, but this has caused lots of companies to drop lots of other chromates too, leading to this problem where the polymer layer just doesn't stick like it used to.
That's another one of my main art materials banned.
So have you found a suitable alternative? These panels are expensive test purchases!
Themagictouch have a new aluminium which they claim has a minimum 5 year outdoor life
Unlike the Choromoluxe and the thinner cheaper versions which are liquid coated this one is double powder coated that doesn't have the chipping problems.
I think it's 1.2mm thick but only comes in white.
I've a feeling someone tried the M.T. aluminium, but it was poor quality? I'll need to find the thread.
I think that may be the Wunderboard which is similar to Chromoluxe, the new one is Duraluxe, which is powder coated rather than liquid coated.
Ricky@Xpres
Hi GaryGoonerGary;132002 wrote:I'm working with some large Chromaluxe panels but having some issues. I can't peel off the protective layer without it taking away some of the coating on the corners.
Try warming the panel slightly before taking the protective film off, a bit of heat frees up the adhesive making it very easy to peel. I tend to leave a panel on the heat press bed away from the element before peeling.
Hope this helps.
Ricky
Xpres
- Has thanked: 11 times
- Been thanked: 9 times
We tried Wunderboard and it was awful quality. SoleJuice & MagicTouch have options for this as well.
My normal method is melting the film off at the corner for a couple of seconds with direct heat. I'll try the whole panel with indirect heat. I try to avoid using fingernails to pick at it, as this is just asking for trouble.Ricky@Xpres;132011 wrote:Hi Gary
Try warming the panel slightly before taking the protective film off, a bit of heat frees up the adhesive....s
But even at the cold parts of the metal, the adhesive should not be taking off the coating. It renders the whole panel useless. I hope Chromaluxe are aware of this?
Ricky@Xpres
Hi GaryGoonerGary;132015 wrote:My normal method is melting the film off at the corner for a couple of seconds with direct heat. I'll try the whole panel with indirect heat. I try to avoid using fingernails to pick at it, as this is just asking for trouble.
This is the first I have heard about the adhesive from the protective film taking the coating off. I normally warm the panel just to make it easier to peel. Did you purchase the panels from us ? If so have you raised a ticket with our tech guys so we can raise it with ChromaLuxe ?
If not i would recommend sending some pictures of the damage to you supplier so they can get feedback from ChromaLuxe.
ChromaLuxe do pride themselves on the quality of the photo panels and coating and are very approachable. Have you had a chance to look at the Start to Sublimate website that they have launched ? Once logged in you can email ChromaLuxe support direct.
Ricky
Xpres
