Would anyone know where to get a suitable replacement silicone sheet to use in these mug wraps
Replacement silicone sheet for wraps
Re: Replacement silicone sheet for wraps
- vB_ID:5159
- 391694435_064.jpg (26.08 KiB) Viewed 13 times
Do a search on this forum, there is a company that I used which was recommended on here but can not remember their name
- UK Printed Mugs
Looks like different sizes available here https://www.printerowners.co.uk/sublima ... -wraps.htm
Customprintwales
I just buy baking sheet silicon from Amazon and cut them down to size. Then you just thread through the new silicon and away you go
You might need a little washing up liquid on to help the silicon go through the bars but it's pretty easy.
Speak to BMS they used to sell it by the square meter if you asked then, as above, cut to size.
Janners
Janners
Why bother though when you can buy the green wraps for a fiver or less from fleabay?
