Heat Press decrease button not working
weecstar
Re: Heat Press decrease button not working
Post by weecstar »
Hi, wondering if anyone can help me?
I have a Stahls Maxx heat press and the button to decrease the temp/time is not working. Everything else works fine.
is there anyway of repairing the button?
no longer under warranty.
I’m panicking now as I’ve got a load of transfers to print at a high temp but won’t be able to drop the temp down again when finished!
Any competent electrician should be able to sort that out. Don't open it up yourself.
Badgers
Post by Badgers »
If you weren't able to get the button alone fixed, a replacement circuit board is only around £80.00 (plus delivery and VAT) and can be changed by a competent electrical engineer - The video below shows how to do it:
https://www.youtube.com/watch?v=1QhSGJDMUvo
weecstar
Post by weecstar »
I haven’t looked into getting it fixed yet but thanks Badgers for the useful info
logobear
Post by logobear »
it will depend on how tech you are.
I fix kit myself, ....
might be able to hack it, but if in any doubt about safety, don't do it!
Badgers
Post by Badgers »
weecstar;131877 wrote:I haven’t looked into getting it fixed yet but thanks Badgers for the useful info
No problem - Hopefully you or someone else can fix the button itself, but at least you have a Plan B if it doesn't work out!
