New to sublimation - time temp and pressure info please
Re: New to sublimation - time temp and pressure info please
Hello
can anyone tell me correct time temp and pressure for printing with subliNova inks and subi sharp transfer paper also pressure
Thank you
Linda
Thank you
Linda
Hi Linda,
Welcome to sublimation! The Temps, Pressures and times all vary per garment/item - not necessarily by ink or paper.
If you've got some materials you wish to print on that you can list - I'm sure we will be able to point you in the correct direction.
Hi thank you for the reply = Im taking thinks slow and starting with 100% polyester t shirts for now.
190 deg C for 50secs works for me, but you may need to vary these slightly for your setup.loobyloo;130245 wrote:Hi thank you for the reply = Im taking thinks slow and starting with 100% polyester t shirts for now.
You must be prepared to lose some items whenever you start up. Nothing is guaranteed in the sublimation game.
- mrs maggot
Sacrifice 1 t shirt, make lots of copies of the same small design, but then write on them diff time and temps so you can get it right, dont start off trying 1 design per shirt - it can get very expensive.
- InkExpress
Hi Linda,
As said we usually recommend speaking with the suppler of the garment or substrate first as the temp and time are dictated by the product rather than the ink or paper. As a general rule we would press polyester t-shirts at 170-180c for 70 seconds. But as people have previously said it is best to try a few different temps and times to see what works best.
But as I said initially do speak to the original garment supplier for pressing info and go from there.
Alex
Alex
Users browsing this forum: Amazon [Bot], Bing [Bot] and 4 guests
