Adkins Xpres Swing Heat Press not heating up. Any Help?
Re: Adkins Xpres Swing Heat Press not heating up. Any Help?
Using an Adkins Xpres heat press and it has suddenly stopped heating up. Checked fuses and the wiring and there is no obvious fault. Anyone else come across this issue and found a solution.
does the display still work?
I get this problem about every 8 years per press.
It will be the power triak on the back/second board (almost probably)
They cost about £100 and can be self fitted but it is quite fiddly, and if you FIU its your hit.
Adkins do a full full service and restore the press to as new for £250 + vat + carrage - unless you can take it to them.
It is a great service, you do get an as new press back.
The service team Stuart & steve are very helpful on [FONT="]Tel: [url=tel:+44%201455%20891291]+44(0)1455 891 291
good luck
[/url][/FONT]
good luck
[/url][/FONT]
Xpres_Adam
Hi Stevysham,
If it's a press you bought directly from us then why not raise a ticket with our techies?
They will be able to talk you through any things to check.
http://ticket.xprestechnical.co.uk/open.php
Adam
Adam
Adam Roberts | System Specialist
Tel: 01332 85 50 85 | DDI: 01332 85 53 29
Fax: 01332 85 50 80
Web: www.xpres.co.uk
Email: Adam.Roberts@xpres.co.uk
Fax: 01332 85 50 80
