Changed yellow, now everything is yellowish tinge
viccar1
Re: Changed yellow, now everything is yellowish tinge
Post by viccar1 »
Ricoh 3110, sawgras subli r ink, trupix paper,
I installed a new yellow, and from first print afterwards everything look right when printed, but when pressed has yellow/sepia tinge to it, the bit thats left on the paper is perfect colour?
Not sure whats going on? surely the ink wouldnt go through straight away after changing, i have tried different pictures ect?
Anyone any ideas before i have to reinstall profiles again :(
John G
Post by John G »
What's the date on the new yellow cart?
Was the cart showing out or low when you changed it? As you say, it shouldn't 'kick' in for a while as the Ricohs hold a fair bit in the lines. Was the outgoing cart still in date? if not, how much out of date was it?
viccar1
Post by viccar1 »
The outgoing cart was out of date by about 6mths, the new cart which i changed when it said empty is dec 2018 so plenty of time.
maybe i should flush the yellow though ?
