Water bottles......can i use a mug press?
carolm1a
Re: Water bottles......can i use a mug press?
Post by carolm1a »
Hi guys
I just wanted to double check before I jump in and buy some :)
Can I use a normal mug press for these https://subliblanks.com/products/500ml- ... ter-bottle it doesn't need any special attachments or anything?>
Thanks guys :)
You can use a mug press BUT you may need a special blanket for smaller mugs. We have an Adkins press and use the porcelain blanket when doing these.
carolm1a
Post by carolm1a »
UK Printed Mugs;129374 wrote:You can use a mug press BUT you may need a special blanket for smaller mugs. We have an Adkins press and use the porcelain blanket when doing these.
I don't have the blanket for my press so wanted to use my oven but its come out looking really naff :(
knightweb
Post by knightweb »
Hi,
I do my water bottles in a Halogen Oven, took a while to get them right, now they come out really good
I'm putting them in at 180 C for 6.5 mins
To get the oven to 180 C, I need to set at 200 C
wendyh
Post by wendyh »
knightweb;129716 wrote:Hi,
[MENTION=5206]knightweb[/MENTION] I'm thinking of trying a halogen oven. Do you use silicon wraps around them? Thanks
knightweb
Post by knightweb »
Hi wendyh,
I just tightly tape the paper to the water bottles, but I do use silicon wraps on all ceramics
Customprintwales
Post by Customprintwales »
Yep I use halogen oven as well with great results. I use a silicon wrap though to keep the transfer in place.
wendyh
Post by wendyh »
knightweb;132447 wrote:Hi wendyh,
Thank you :smile:
Customprintwales;132448 wrote:Yep I use halogen oven as well with great results. I use a silicon wrap though to keep the transfer in place.
Thank you [MENTION=7433]Customprintwales[/MENTION] :smile:
You can print them with a 10oz mug element in the Adkins, just put a thin silicone matt in between to take up the extra space.
