How about MUgAnimator 4.0?
Any OS, software in here.
Re: How about MUgAnimator 4.0?
So I worked hard to improve what I already got and made some changes in this version.
New layout, New version update window, some bugs fixes.
More mugs:
  • Standard 10/11oz mug
  • black mug with white patch
  • sparta mug
  • metal and plastic travel mug
  • Slim mug
  • colour rim and handle mug
  • OKI laser mugs (several colours)
  • TREK mug
  • WOW mug (still in BETA - plenty to improve)
In the pipe line for version 4.1
  • Enamel metal mug
  • hardwood coaster
Also both, Windows and MAC versions are available. Mac version is still in BETA and there is few glitches to fix. At this moment MacOsX version will only open images from first partition of your mac. Like DOWNLOAD folder. All files Can't have space in the file name. Sorry about that. I am working on fix.
You can download your version in usual place
[CENTER]
vB_ID:5004
vB_ID:5004
Screen Shot 2018-01-17 at 08.00.21.jpg (17.09 KiB) Viewed 14 times
DS Designs
Post by DS Designs »
Nice work Paul, thank you. One quick question...on playback it only rotates about one and a half times. Is there a setting I'm missing for it to rotate continuous?
Cheers....Dave
Hi,
it should give you full 360 degree turn. But it also depends of your pc capability.
GIF only give you one animation. It wont loop in the gif. Is up to software you use . So if you open your gif in exploer it will only turn once by default. So settings need to be changed. But for example irfanView will loop it.
Forgetful8
Post by Forgetful8 »
Awesome! I'll be honest - I quite like just playing about with it - no real reason. It's a bit like leaving dymo label makers in my possession...
(I definitely did not* keep changing my last Navigators name on the pegboard to something slightly inappropriate :biggrin:)
*That may also definitely be a complete lie...that's not the worst I did to him though - even funnier, he never managed to get revenge hehe
[CENTER]A bored sailor is a mischievous sailor...
Boy, am I bored!
DS Designs
Paul;129252 wrote:Hi,
So what settings need to be changed...any ideas?
logobear
Post by logobear »
great program.
It automatically inserts the image top left.
any way to centre it, or expand it to fill ? or control placement?
We typically leave about 10mm top and bottom, but obviously, everyone will be different.
We could create artwork with white spaces around .....
do you have any image size/dpi suggestions to get the best from it as is?
thanks
phil
Hi Phil. When you upload your image you will find tiny white arrow in the bottom right corner. dragging it you will be able to resize it the way you want. this will help you do little gaps on top and bottom of mug. Check this example.
vB_ID:5008
vB_ID:5008
mrs maggot
Post by mrs maggot »
Paul, I am so sorry, I meant to come on and rave about it the other day, but I forgot - old age is to blame no doubt. It really cannot be compared to the earlier versions - well done you .
Thank you Laura. I am still working hard on it. I will upload slates soon too :D
GM21
Post by GM21 »
Fantastic work Paul love this tool!
Sent from my SGP512 using Tapatalk
