Printable vinyls?
paul 44
Re: Printable vinyls?
Post by paul 44 »
Hi folks,
I have a few shirts to do which are 100% poly, not going to use 3g or jet opaque on them as they bleed major even with 5-10 second bursts so question is, do any of you recommend any printable vinyl that I can use via my inkjet (pigment) or ricoh 3110?
I know there are printable vinyls out there but need some pretty decent stuff that I can put through an Epson A4 printer and that I know will last.
Paul, I used 3g on those polyester drawstring bags I posted a pic of in another thread and had no bleed whatsoever. Printed with CIE sublimation inks with a Ricoh 3110.
paul 44
Post by paul 44 »
Im getting major bleed on 5 secs on a galaxy cap press, let it cool for a bit then press it again and it just gets worse each press, all the white just turns black/red
paul 44
Post by paul 44 »
anybody tried this from BMS?
160c press and 15 seconds?
https://www.printerowners.co.uk/m/garme ... e-flex.htm
