Looking for a Protective Cling Transparent Film.
Discuss other print methods.
Stitch Up
Re: Looking for a Protective Cling Transparent Film.
Post by Stitch Up »
Hello all
I have a Yamaha keyboard (pride & joy) that cost me a few shillings :) I like to keep my 'toys' in very good condition and would like to make some sort of transparent, cling cover to protect the surface/legend etc as with continuous use, can wear away.
I would create templates in manageable parts as indicated by the red squares. I know I can buy ready made protectors but I thought this might be a good project for the BN-20 or any cutter for that matter :)
What product would be best suited for this project? It would need to be glue-less for ease of placement/removal and not to leave any residue behind.
Any ideas?
Cheers
John
Hi John
What is the silver case made of?
If its plastic I think that might limit your options.
The only glue-less clear film I can think of that might work is static cling. Give Metamark a call and they send samples which will probably suffice for plenty covers.
Hi John, nice keyboard, beats my Yamaha PSR to hell! :smile:
I was thinking, if the panels you require aren't too large, maybe use a screen protector for an iPad or large tablet, cut with a contour cutter. They leave no residue when used on phones and tablets, so may do the job. There may be air bubbles though if the material of your keyboard is textured and not smooth Worth a try on an unobtrusive area though.
Stitch Up
Post by Stitch Up »
@socialgiraffe
Yes, it's some sort of plastic. Would have to be some sort of cling material as any glue would probably leave a residue. Protective clear covers are available from one supplier, I just thought this could be something I could do with my cutter :)
@webtrekker
The Yamaha Tyros 5 is amazing and I haven't even scratched the surface of its capabilities yet! The biggest issue I have right now is, full-time job, Stitch-Up shop and then family!!!
You're right, the material they use for screen protectors might be the deal for this - I'll have to source it in a roll. I'm sure I have some cling somewhere!!
Thanks both
John
Users browsing this forum: Bing [Bot] and 2 guests
