Reds printing orange on ricoh 3110
paul 44
Re: Reds printing orange on ricoh 3110
Post by paul 44 »
Hi folks
Any ideas as to why a mug which should be red is printing orange, it's kind of between an orange and red but not pure red as it should be?
Printed from photoshop with RGB colour setting and correct profile assigned, printed via the powerdriver at 180 seconds at 170c, no pre-heat on the mug at all as wanted it to raise itself to temp then cook it.
Mugs are orca coated from dyesublimation supples and was printed at max pressure.
Press was a freesub double mug press.
daviddeer
Post by daviddeer »
Have you checked it is not out of gamut.
paul 44
Post by paul 44 »
it seems to be ok, no warnings or anything popping up so not sure, its probably 80% red and 20% orange
