car and stickers paper
Re: car and stickers paper
Does any one do these and what would you recommend for both. I get confused ,What paper is for inside the car for the window, and what to use for out side of the car and suitable for outdoors.
For inside you can either use cut (mirror image) or printed (if done on clear) normal sign vinyl, or static cling vinyl, I bought a pack of the static cling from this company worked well through the laser printer, then backed it with sign vinyl.
http://www.consumablemad.co.uk/shop.asp ... pcatid=130
For exterior you can use cut normal vinyl, or again print using either colour laser, inkjet or thermal resin (like used in the Edge printers or the older (like mine) Roland ColorCamm). Printed vinyl using these methods really should be laminated to prolong the life of the print. I use liquid laminate from Grafityp (commonly known as "Frog Juice") and brush it on with a foam brush.
Hope this helps.
Sharon
Hope this helps.
Sharon
or, like the old days - go see a screen printer and they'll sort you out!
Aah good old frog juice i use this on my canvases, intersting in didn't know it could be used on stickers too.
Take a look at this jennywren [url="http://www.dyesubforum.co.uk/forum/view ... =39&t=1411]viewtopic.php?f=39&t=1411[/url]
he will be able to help you, good prices too and you know they will last outdoors!
