coasters
robhil
Re: coasters
Post by robhil »
Hi all looking for some help please.
I have to do some coasters which are white at the outside edge, I have a template done in PS elements 15 with no border so when printed I have no way of knowing if I have placed the coaster central.
How do you put a border around the square in PS.
Re: coasters
Add 2mm square all the way around so you have a bleed. 90mm coasters therefore would be 92mm square.
robhil
Re: coasters
Post by robhil »
Thanks Justin
I have actually made my sq. 91mm but with no border visible border, so my problem is (apart from being thick) I don't know how to put a visible border around it.
Re: coasters
Post by GoonerGary »
So a 90mm coaster will maybe have a print size of 94mm? I add that image to a blank A4/ A3 printing template. Add a 1 pixel stroke on the outside of the 94mm printed image. Easy to line up.
