Roland EcoSol Max 2 440ml cartridges x 4
Ali P
Re: Roland EcoSol Max 2 440ml cartridges x 4
Post by Ali P »
Due to a purchasing error (don't go there) I need to sell a set of Roland Ecosol Max 2 cartridges. Black and Cyan are unopened and the Magenta and Yellow are unused but opened as they were put on to the machine today. Dearest Roland very unhelpfully waited until both were attached to him before he pointed out that they were the wrong ones.
I would like to offer them for £70 each (a saving of around £23 each). Alternatively a swap for EcoSol Max could be helpful - if anyone has any EcoSol Max for sale please let me know.
I also still have a set of the Upgrade EcoSol Max 3 for sale as per previous post...
Thank you all
logobear
Post by logobear »
what is the code written on the out end of the cartridges?
when did you get them & where from?
thanks
Ali P
Post by Ali P »
logobear;125750 wrote:what is the code written on the out end of the cartridges?
thanks[/UOTE] is the code written on the out end of the cartridges?
thanks
Hi Logobear, I bought them on 3rd July this year from Digiprint Supplies http://www.digiprint-supplies.com. I am not near Roland at the moment so will check the codes later and post an update. They are genuine OEM cartridges, not compatibles.
Ali P
Post by Ali P »
Please see images attached:
vB_ID:4823
vB_ID:4823
vB_ID:4824
vB_ID:4824
vB_ID:4825
vB_ID:4825
Ali P
Post by Ali P »
And these are the two we were replacing so you can see from the code that they were Ecosol max and not Ecosol max 2.
I should have just checked previous receipts rather than relying on what is obviously not a very good memory!
vB_ID:4826
vB_ID:4826
logobear
Post by logobear »
we also use the ESL 3-4
i also get confused by the names
Ali P
Post by Ali P »
logobear;125782 wrote:Thanks
That's a shame - you won't be wanting to buy mine then Image
What also doesn't help is the fact the packaging is so similar, otherwise we might have realised our mistake sooner.
