Xpres paper and black
Re: Xpres paper and black
I am aware I am not the only person that has discovered that the Xpres paper has a problem with solid black. A residue from the paper (the top coat?) gets left on the mug. It will polish off but it isn't an extra task I want.
I have just placed a new order for paper and gone back to trupix, essentially I want to print, cool, pack and post. Checking to see if a mug needs a polish isn't in my work schedule.
So who else has noticed this?
Janners
Janners
bubbleimages
Very interesting to see Xpres offering 'a range' of different papers. Seems to be an offering of old when different papers for different blanks was the order of the day.
SubliPrint Light, SubliPrint Universal, SubliPrint Thermal, Beaver Print XPHR....or Trupix! lol
Hi Bubbleimages.
I have access to 3 sets of mugs and the same result on all.
Janners
Janners
This is through my ricoh so sawgrass inks with sawgrass powerdriver standard settings. I haven't used xpres paper in the other printer as it's profiled for different inks and paper.
Janners
Janners
XpresGrant
Hi all,
Our new SubliPrint Premium has been profiled by Sawgrass for use with their Virtuoso Print Manager, Xpres Edition, when using a Sawgrass Virtuoso desktop printer.
This will ensure that the optimum amount of ink is printed onto the paper depending upon the substrate being imaged, therefore not laying down excess ink where it is not needed.
It will also print well with the Ricoh printers using a Sawgrass ICC profile or PowerDriver.
With regards to deep black and large areas of dark colours, it is essential to make sure that the ink is completely dry before pressing. It is not recommended to print and press instantly, instead leave the paper to dry for a few minutes. This should resolve any residue transferring with the dark ink onto hard substrates.
Our range of roll media for sublimation has been introduced for wider format printers (44"-64"), such as the Epson SC-F6200/7200/9200, Roland TexArt RT/XT640 and Mimaki TS300P-1800 / TS30-1300 that Xpres supply.
Our 90gsm Universal is recommended for a range of substrates, both textiles and hard surfaces.
The 70gsm Light is designed for textiles only, due to textiles absorbing less ink than hard substrates, there is no need for a heavier paper if less ink is being laid onto it. This works very well when using a Rotary / Calendar press rather than a flatbed heat press.
A tacky paper, such as Thermo 90gsm, is also recommended for textiles, especially when heat pressing rather than calendaring, as the heat activated adhesive helps to stop the polyester textile shrinking, in turn avoiding ghosting.
Finally, Beaver Paper is a 105gsm ChromaLuxe recommended paper, suitable for all purposes.
We have samples of the above papers available for testing - please call 01332 85 50 85 to arrange a sample or discuss further.
- UK Printed Mugs
Hi XpresGrant. The issue with black is not with the black drying but actually transferring to the wheels inside of the printer causing ink to be spread across the artwork and the next paper sheet.
Andysam26467
Totally agree with UK Printed Mugs. It's the ink transferring to the printer rollers and putting line down the print. We have reverted back to Trupix. We have 5 packs of Xpres paper sitting on the shelf
Can someone post some picks of bad prints? I'd like to see if we all have the same problem with block colours.
