We've just in the middle of a large cushion run, so I took a batch of the print job, weighed the ink cartridges before and after to calculate ink usage for the job.
This is using an Epson 9600 on Enhanced Matte paper setting, high speed. Using InkTec's Sublinova (DTI) Ink.
Each of our cushions uses a transfer 1 metre wide, and 50 cm high (so a half square metre) and are printed full colour bleed edge to edge, so total ink coverage for the transfer.
We used a run of 35 cushions from the batch, so 17.5 square metres
The ink usage in grams was as follows:
[TABLE="width: 478]
[TR]
[TD][/TD]
[TD]Before[/TD]
[TD]After[/TD]
[TD]Colour Usage[/TD]
[/TR]
[TR]
[TD]Yellow:[/TD]
[TD="align: right]484[/TD]
[TD="align: right]438[/TD]
[TD="align: right]46[/TD]
[/TR]
[TR]
[TD]Light Magenta:[/TD]
[TD="align: right]493[/TD]
[TD="align: right]442[/TD]
[TD="align: right]51[/TD]
[/TR]
[TR]
[TD]Light Cyan:[/TD]
[TD="align: right]499[/TD]
[TD="align: right]444[/TD]
[TD="align: right]55[/TD]
[/TR]
[TR]
[TD]Magenta:[/TD]
[TD="align: right]530[/TD]
[TD="align: right]487[/TD]
[TD="align: right]43[/TD]
[/TR]
[TR]
[TD]Cyan[/TD]
[TD="align: right]513[/TD]
[TD="align: right]400[/TD]
[TD="align: right]113[/TD]
[/TR]
[TR]
[TD]Light Black:[/TD]
[TD="align: right]515[/TD]
[TD="align: right]486[/TD]
[TD="align: right]29[/TD]
[/TR]
[TR]
[TD]Black:[/TD]
[TD="align: right]468[/TD]
[TD="align: right]45[/TD]
[/TR]
[TR]
[TD]TOTAL[/TD]
[TD="align: right]3547[/TD]
[TD="align: right]3165[/TD]
[TD="align: right]382[/TD]
[/TR]
[/TABLE]
So, in total 382 grams of ink
I took an average weight of 3 full (unopened) litres of ink I had in stock (which were all different weights) and got an average of 1079.333g for a litre of ink (factoring in the 103g for the bottle itself)
So, 1 ml of ink is equal to 1.079333 grams
So, for 17.5 square metres, we used 412.3053 ml of ink
Which comes down to 23.56 ml per metre
(happy to be corrected if I got some of my calculations wrong!)
Ink Usage
Re: Ink Usage
Plus the transfer paper, electric, time, wear and tear..... ummm expensive production costs.
Re: Ink Usage
i suspect an error, - 382 grams - that's nearly a pound in old weights, - that is way too much .... me things for 35 cushions ? - but what do i know!
it's a lot of liquid to evaporate off...
Re: Ink Usage
Just printed several square meters of wide format media in the last 5 hours looked at the actual usage and calculated what I would have used if I continued to print 35 square meters and it worked out at 240cc
Re: Ink Usage
Got some of my maths wrong, which gets it down to 20.22 ml of ink per square metre.
@ArferMo - 35 cushions is isn't 35 square metres, as each cushion is half a square metre of fabric (50cm x 1 metre)
- in terms of expensive production costs, we are dealers for InkTec, so get the inks and transfer paper at trade price not RRP
- our costs for print, cut and sew cushions work out better than buying in blank sublimation cushions to print on
@logobear - the scales are probably not accurate enough for this to be scientifically accurate
@GoonerGary - no, our ink costs a lot less than that!
I think if we using Sawgrass consumer inks, with their £60 for 100ml or whatever Artanium costs, then the ink per square metre costs would be silly
