Do I need a new printer or can I use my Dye-sub printer?
Username
Re: Do I need a new printer or can I use my Dye-sub printer?
Post by Username »
Hi all,
I am new to this group and new to the mug printing world, anyway I own a mitsubishi cp70dw can I use that dye-sub printer for the heat transfers or do I need to swap over and get a Epson printer and put the dye-sub ink init?
Thank you all for your help, also I am from Australia :)
So-called 'sublimation' when applied to photography is is a totally different process to the sublimation process applied to polyester containing, or coated, items as discussed in this forum.
You will need a specific printer that will handle sublimation inks (most popular are Ricoh and Epson), special paper, a heat press, or presses, and an ICC profile to match the inks you are using.
Username
Post by Username »
webtrekker;124710 wrote:So-called 'sublimation' when applied to photography is is a totally different process to the sublimation process applied to polyester containing, or coated, items as discussed in this forum.
Thanks mate for that, I had a feeling that would be the case but thought I would ask anyway seeing as I have one sitting at home, I am looking at the Epson WF-2630 but being in Australia we have a lack of sellers who sell the ink so I need to look at buying in from overseas or the stuff I can get is the no name brand ink and I do not know how good it really is.
