Paul - Craft Robo
AJLA
Re: Paul - Craft Robo
Post by AJLA »
Hi Paul,
I remember a while ago you saying that your robo was starting to slow down or stop like it thinks it was overheating,( I can't find that post anywhere ) mine used to do this only when cutting one of our more comlpicated ai files. Unfortunately it's now doing it at very strange times, ie when i first turn the machine on. It will stop as though it is overheating at the begining of cutting 3 very simple words. It thinks about it for ages before actually cutting, then afterwards I can do lots and lots with no problem at all which is very odd.
Did your Robo go in the bin or is it still going? I'm hoping mine is just having a "senior moment" and forgetting what it's job is but i'm not sure if i should invest in a back up just incase.
hi! My robo was this same. I noticeds it was slowing down only with 2 of my designes. simply buffor of CR was overloading to quick :)
with other designes is still ok. I am not using it any more as I own biger cuter now so soon on ebay :)
but still cuting well.
is your wording is simple typed words and sent to CR? or you convert them as curves first then sent it to cr??
AJLA
Post by AJLA »
Just simple words typed into CR Paul, could not be more simple which is why it is odd.
hmmm sounds odd. as cr buffor is small but not that small. I realy dont know what to tell you and how to help :( maybe is worth to give them a shout at graphtec??? I read somwhere they preaty good with customer service.
paul
