Hi All, new to silk screen and exposing screens etc. I have a litre of emulsion but i am aware that once its mixed with the activator it has a shelf life which can be lengthened if you put it in the fridge. I am on a very tight budget which is why i brought the litre tub as it saved money but i doubt i will use it all before it goes off which will waste money.
Can I split the emulsion and the activator into smaller amounts. Once the water is in the small activator bottle does it have to be used ? I'm just thinking i can weigh and work out smaller amounts easily so i don't use it all at once.
Jord
Maximising Emulsion life
Re: Maximising Emulsion life
Jord
Noob to Silk Screen printing only just got my gear so please don't shout at me if I ask a dumb question. Self built (Bob Mongiello) multi-colour screen press. Plastisol inks. Halogen light Exposure unit
Jord
- Been thanked: 12 times
You can buy another sensitizer for some emulsions, I moved over to pre mixed that last 12 months after I had a lot of issues with the 2 part going out of date very quickly.
I'm just tight, and need to save as much as possible till i get better and get a few orders in.
Jord
Jord
You might want to look at buying pre-emulsioned screens or maybe even pre exposed screens. If you're charging the right amount for your setup this would be covered.
Yes it could be an option IF or when i do get an order that warrants it and also it depends on how much a pre-emulsioned/exposed screen costs. I am thinking about having a setup cost if possible but i don't want to scare any potential customers away, trouble is everything costs in this day and age. As i've not emulsioned any screens and burned them yet i will see how i get on with the procedure, how long it takes me etc. At the moment i cant calculate time into any jobs as im such a noob. but you have given me something to think about.Justin;124625 wrote:You might want to look at buying pre-emulsioned screens or maybe even pre exposed screens. If you're charging the right amount for your setup this would be covered.
Jord
Jord
Jord
Does anyone have any names or brands for the pre mixed emulsion? Also how long will it last ?
I believe that the diazo stuff i have will last a few months in the fridge (i will have to go check what brand/make it is as it still in the cardboard box everything was delivered in) Its the "hybrid" 2 part Diazo emulsion from art2silkscreen so I have no clue how good it is, I just didn't buy the cheapest.
[h=1][/h]
[h=1][/h]
Jord
Jord
