Epson 1500 - Ink stability
green19
Re: Epson 1500 - Ink stability
Post by green19 »
Hi all wondered if anyone had advice or solution I have an Epson 1500W (great printer) using sublimation ink on a CISS system BUT with the extremely hot weather of late the inks just keep drying up and I'm have to prime as it is only a hobby I would say I only use the printer 3/4 times a week .................. just wondered if anyone had any solutions to stop this .................... thanks in advance all
James990
Post by James990 »
Keep it out of the sun!
Where are you storing it? in an oven!!!!
If you are using it 3/4 times a week it should not be drying up that quick. I would recommend you move it to a cooler and shaded area.
green19
Post by green19 »
Ill give that a go
