The perfect mug....
Re: The perfect mug....
Hello
We are reverting back to pressing our own mugs after having big quality issues with the ones made for us. I've narrowed the mug blanks down to these:
BMS Euro
Listawood Duraglaze AAA
Xpress 5013
Raja - not sure which one, still to talk to them
I need a mug that is 10oz, straight sided (printing top to bottom, full wrap), non-staining on the inside, completely dishwasher proof and no pin holes etc. Also needs to be economical to order by the pallet.
Out of these options are there any you wouldn't use? Will probably have to rule out the BMS ones on price but I know these are excellent mugs. I've already ruled out subli as they have Orca stamps on the bottom.
TIA
BMS Euro
Xpress 5013
TIA
- UK Printed Mugs
Xpres personally. We do buy Listawood some times but find Xpres coating better and we can dunk them in water without cracking which we do find Listawood ones do although not sure what temp our water is. For large print runs we need to dunk in water in order to cool quickly and then pack.
Xpres 5013 for me as well
Remember as a premium member you get best price break on these as well.
Thanks for the replies. I think the water dunking is the reason for the quality problems we are having with our current mugs - they are crazing in the insides and getting returned by our customers after a few uses - not good! I think the company that print them for us use the Subli Orca mugs. I've asked for a sample of the Xpres mug to try. Forgot about the discount too
I posted a reply earlier comparing the Listawood and Xpres mugs. I used to buy pallets from Raja, but had quality issues with their 10oz mugs. The Raja mugs are identical to the Xpres mugs. The Listawood and BMS mugs have collective amnesia about the pinhole issues in the coating, so personally I'd go for Xpres mugs. There is no perfect mug mind you.
Never had any troubles with the Listawood 10oz AAA's. I check 100% through each box as soon as I receive them and have yet to find a dodgy one.
Personally prefer the BMS European, however Parcelforce are a shambles up here so unfortunately have to rules them out. Next best option is the Xpres 5013. Never had one complaint from a customer and every mug has arrived undamaged.
Order before 5pm, on my doorstep by lunchtime in Glasgow next day with DPD. Tried pretty much every other brand of mug and those are the two that stand out, Listawood mugs also very good and would use them as a back up.
We're in Grangemouth - feel your pain with Parcelfarce! Sounds like Xpres is the way to go. We used to use the BMS ones when we were retailing them at a tenner each but now mainly wholesale for a lot less so the margin just isn't there on them.technick;123997 wrote:Personally prefer the BMS European, however Parcelforce are a shambles up here so unfortunately have to rules them out. Next best option is the Xpres 5013. Never had one complaint from a customer and every mug has arrived undamaged.
I can't stand pin holes - might not be a problem for many but a white dot in the middle of full wrap artwork is a disaster. Xpres it is thenGoonerGary;123983 wrote:I posted a reply earlier comparing the Listawood and Xpres mugs. I used to buy pallets from Raja, but had quality issues with their 10oz mugs. The Raja mugs are identical to the Xpres mugs. The Listawood and BMS mugs have collective amnesia about the pinhole issues in the coating, so personally I'd go for Xpres mugs. There is no perfect mug mind you.
Xpres have everything i need under the one roof - their quality and customer service is great plus you will get an extra 10% off on here using the codeVioletsub;123999 wrote:We're in Grangemouth - feel your pain with Parcelfarce! Sounds like Xpres is the way to go. We used to use the BMS ones when we were retailing them at a tenner each but now mainly wholesale for a lot less so the margin just isn't there on them.
