Best Route Forward with Ricoh Printer
mrs maggot
Re: Best Route Forward with Ricoh Printer
Post by mrs maggot »
We have GXe3300 printer and use the expensive Subli cartridges - our problem is we don't actually use it that much. I would estimate from the last cartridge change to the one now due we have used around 80 sheets of paper. I have kept the machine switched on the whole time as I was told by Sawgrass it was better left on all the time.
Is anyone else use their printer for such small amounts of use - I know we have wasted so much ink in keeping it on, and it going through its cycle all the time.
So turn it on when needed - what are the risks - clogged up heads?
keep it turned on, and know that the £££'s are just being cleaned away?
Get rid of it, and outsource my printing needs?
SciArtImages
Post by SciArtImages »
I've had my 3300 for over 5 years and just switch it on when needed - I don't print massively often either. Last week I had to do the (I think) first head clean in all that time on one of the heads due to it going a bit fuzzy. All fine now, so I would keep it switched off rather than waste ink.
Neil.
Science meets Art - microscope photographs revealing the beauty of the world around us.
http://www.sciartimages.co.uk
http://www.facebook.com/SciArtImages
Keep off. Use when needed.
mrs maggot
Thanks for that, me thinks perhaps keeping it on, is better for sales of ink than keeping it off !
logobear
Post by logobear »
we have a 3300 for maybe 5 years and found it wonderful.
We might do 10 mugs a week .... nearly every week, - and 4 times a year need to do 100 or 300 mugs ... and it has always worked.
Never ever ever ever done any flush,
always left switched on.
Cartridges seem to last forever.
Am I doing something wrong>?
mrs maggot
no, we must be, cartridges were new last february, and are now 2 are empty, and like I say we have only done about 80 sheets !! every once in awhile, it chunters away to itself - so must be doing some sort of cleaning and I have thought that is where the ink is going, into the waste cart not onto paper!
catcapers
Post by catcapers »
I had the same problem at first. Didn't do much printing and got through three cartridges in a year with the waste unit 80% full! I found that doing a regular weekly print even it was only a couple of sheets made a difference otherwise the machine is constantly cleaning itself and wasting ink.
Strangely enough I have updated the firmware and the machine switches itself off after around 2 hours in sleep mode. When switched back on it seems very efficient without endless maintenance cycles and now my carts are lasting a lot longer. So fingers crossed.
